If it is 100 deg outside, it will be at least 100 deg in the cockpit, there's no A/C. When the canopy is closed ans the sun is out, it heats up quickly inside. BUT, many of us have very effective ventilation systems that blast a LOT of outside air into the cockpit, that feels great and helps a lot. Remember that the dry adiabatic lapse rate is about 3.5 Deg F per thousand feet: If it is 100 F at your airport when you take off, it will be a comfortable 75 deg F outside your plane when you climb 7000 Ft (will probably take 12-15 minutes with both of you aboard). Heat: You can instal a heater if you want.Texfly wrote:-Does it get hot in the cockpit? What about being cold in the winter, is there a heating system?
You'll need to sit in a Sonex to see if it is comfortable for you. Find one with the now-standard lowered seat (due to your height, it might be an issue, it depends a lot on your sitting height). The Sonex is not a big plane.Texfly wrote:-I have read that the cockpit width is 40". I'm 6'3" 195lb. Do you think I can fit with a passenger (normal sized wife)?
Some headphones have a jack for use with a cell phone. I do not know if it is technically legal (according to the FCC) to use a cell phone in a moving airplane, but aside from that I believe it will work fine. You'll be up in the air for 3 hours max--most people can probably wait to hear from you guys until you land.Texfly wrote:-Even with the vibrations/engine noise can you still call anyone with a cell phone if needed?
There is no maximum wind. I don't have my POH nearby, but I think that it says that a crosswind component above a certain amount for takeoff requires additional caution. Someone may chime in with the exact number. As a practical matter, a lot will depend on your proficiency and whether you have a trigear or taildragger.Texfly wrote:-What's the max suggested wind to safely fly a Sonex?
Yes, you pretty much have to in order to get to the "far" seat. If you are sitting on the left side, it is possible to avoid stepping on the seat by lowering yourself in. I keep a towel in there to step on.Texfly wrote:-Do you step on the seat when going in?
Mine don't, my wife never mentioned any issues.Texfly wrote:-Do you feel vibrations in the feet (since they are so close to the firewall)? i.e. in a 2 hour commuting flight do you get your feet/legs numb?
Users browsing this forum: No registered users and 76 guests
