Mains tire pressure?
Postby jcondon » Fri Jul 25, 2014 4:55 pm
I can't seem to find the recommended mains tire pressure for a conventional gear OneX. The aluminum wheels are marked with 30 PSI maximum and the tires with 70 PSI maximum. Think I read where some people were running pressures above the 30 PSI wheel maximum. I haven't contacted Sonex yet but can if no one knows the recommended pressure.
jcondon
Re: Mains tire pressure?
Postby wlarson861 » Fri Jul 25, 2014 5:23 pm
on the Sonex they specify 50 psi.
Bill Larson
N861SX
wlarson861
Postby daleandee » Fri Jul 25, 2014 7:54 pm
Postby Fastcapy » Fri Jul 25, 2014 10:29 pm
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby radfordc » Fri Jul 25, 2014 11:09 pm
Fastcapy wrote:Happened to a fellow builder I know.
Happened to me, too. I was running 35...now I use 50.
radfordc
Postby DCASonex » Sat Jul 26, 2014 9:46 am
Might get by with slightly less pressure for the lighter weight Onex assuming it uses same tire size. One note: I am using the optional 5.00 x 5 tires on my Sonex, and run about 25 PSI with those. If 50 PSI were used with the bigger tire it would put way too m much force on the 30 PSI wheels.
Postby pilotyoung » Tue Nov 07, 2023 3:06 pm
Is there a consensus on the proper tire pressure for the main wheels on a Onex?
pilotyoung
Postby rbarber » Tue Nov 07, 2023 4:21 pm
I have been using 50 PSI for over a decade. I started using 30 PSI, but kept having the tire spin on the wheel after the pressure crept down even a little. Now I never let it get below 30 PSI. I have no idea how the makers of the TriStar brand of wheels came to the conclusion that 30 PSI should be the maximum, but more than a decade my "landings" on this setup tells me that the Sonex advice (50 PSI) is sound.
rbarber
Postby Bryan Cotton » Tue Nov 07, 2023 4:28 pm
50 psi here, but it always ends up at 45. That seems ok too, but I don't go lower than 45ish.
Not sure why this would be different for a Onex.
Postby pilotyoung » Tue Nov 07, 2023 5:11 pm
Thanks. I have been using 25 and I am going to increase it to 50 psi and see what happens.
pilotyoung
Users browsing this forum: Bing [Bot] and 44 guests
