vertical fiberglass tip
Postby Mike53 » Sat Jul 19, 2014 7:55 pm
What are builders doing to get a smooth transition to the fiberglass tip ?
The tips look nothing like the drawings ,not even close.
Are you trimming them at the front so that they will sit lower, and then trimming the rear so that the rudder fits ?
Thanks.
Mike
Mike
Antoine de Saint-Exupery
Mike53
Re: vertical fiberglass tip
Postby A10snoopy » Sat Jul 19, 2014 8:32 pm
Mike, I trimmed about 3/4 inches from the bottom of the vertical and the horizontal tips with a dremeI tool using a cutoff wheel. I accepted the fact that that makes them a little shorter than the rudder and elevator. Paul Onex 76
A10snoopy
Postby Mike53 » Sat Jul 19, 2014 10:00 pm
Thanks Paul.I knew I would have to do something,just wasn't sure what.3/4 of an inch it is :!:
Cheers.
Mike
Mike
Mike53
Postby rk2436 » Sat Jul 19, 2014 10:35 pm
Mike,what you cut off the bottom will bring the length in closer to match up with the rudder. Don't cut the rear edge to change the length,now the factory built in warp of the trailing edge is another animal.
Bob K
Orig builder kit 1143
Now flying RV-12
Evergreen Park,Il
rk2436
Postby Mike53 » Sun Jul 20, 2014 2:54 pm
Thanks guys.I took the 3/4" off on my table saw (80 teeth)and it worked out great :D
Cheers,
Mike
Mike
Mike53
