MichaelFarley56 wrote:I do believe it's pretty normal to weigh down the tail when you're at that phase of the build process. Once you install the tail it won't be an issue.
MichaelFarley56 wrote:Is the engine preserved at all? Is there any oil in there at this point?
Personally, if it were me, I'd probably wait a little while. I decided that I wasn't going to start my engine until I had the electrical system completed so I could monitor all engine temps and pressures even on the first start. Plus, I knew the engine pieces had a protective layer of oil and white lithium grease on the bearings that I didn't want to burn off by running the engine then letting the thing just sit there for long periods of time. The last thing I wanted was my brand new engine rusting on the inside!
MichaelFarley56 wrote:But, it's obviously your choice! :mrgreen:
Bryan Cotton wrote:I would wait.
mike20sm wrote:I like your paint scheme. How are people painting their piano hinges without having them bind up or have interference issues? Do they tape them off and not paint them at all?
Users browsing this forum: No registered users and 21 guests
