by kevin814 » Wed Jun 18, 2014 9:10 pm
In the interest of possibly saving someone from engine damage or a dangerous situation, I just wanted to let others know about my experience with Decalin (used with avgas to help prevent fouling and lead build up in the cylinders). I bought a bottle and added it to my fuel tank before refilling. During full throttle climb out it seemed the power was down and the engine seemed to miss. Also while I was trying to diagnose the problem I would open the throttle during level flight, and the engine seemed to miss and the EGT's went through the roof! I thought it may be running to lean, so I also tried pulling the primer (Rotec TBI) during full throttle. Hmm.... even with extra fuel it was still "missing" and EGT's shot up. I thought this may be due to a fuel restriction or clogged jets, and flew it a few more times trying to diagnose it. Then I remembered it started about the time I used the Decalin. I pumped the fuel out, and put in straight avgas and the problem disappeared. In hindsight the engine (Jabiru 3300) was severely detonating (pinging). The information I've read about Decalin says it won't reduced octane, and that it only becomes active during the moment of combustion, but in my case the detonation was extreme. Hopefully I didn't do too much damage to the engine. I've tried Techron fuel system cleaner, and that also caused detonation. Now I avoid fuel additives like the plage, and have also had good luck with Mogas.
Just wanted to share my experience....
Kevin K.
Kevin K.
Cincinnati
Sonex 130 Taildragger, Jab 3300 w/Rotec TBI, 6" tailwheel,
