MichaelFarley56 wrote:Strange question Mike, but when your carb is sticking, do you have the cowling on or off? I've done some tuning on mine without my cowling and have seen a lot of condensation (even frost at times) form on the Y pipe intake tube just above the carb, and occasionally my slide can stick as well. I've thought of this as a possible issue with said condensation and things getting cold. When my cowling is on however, I've never had this issue.
If needed you can always disassemble your AeroInjector and make sure there's no debris causing issues. Finally, you've already said it but make sure your throttle cable doesn't have any sharp bends which could bind up the cable movement.
Keep us up to date on how final prep goes for your first flight!
