SonexN76ET wrote:Disconnect your P leads and see what happens...
radfordc wrote:They say experimental aviation is about "education and recreation". I think you're getting the "education" part now.
SonexN76ET wrote:Mike,
Before you go through all this trouble in taking the engine off, may I suggest you try one very simple test? Everything you have described sounds like it is a grounding problem.
Run an 18 gauge ground wire directly from the battery to the engine block (not the mounting plate), then run a wire from that connection on the engine block to the magnitron. Also, disconnect your P lead.
This test should only take a few minutes. If this does not work it will have ruled out a grounding problem. If it does work, it will have saved you countless hours. This follows the same logic of running a negative lead directly from the battery to the starter. Paint, surface oxidation, dissimilar metals, etc, all can cause poor ground continuity.
I agree with Sonex that it is not the magnet. If it was the magnet, the lower magnitron should not fire either. I do not know how you could do a magnet test with the engine mounted with all the other metal in the way, so I would not be that confident in the magnet test. Also, as shown in the manual, different compasses show different results. When your friend tested his magnet, did he use the same compass?
I would recommend not "over thinking" this. The magnitron system is as simple as can be. It can only be one of six things: a bad ground (to magnitron or to engine block), a p-lead being grounded unintentionally, a bad magnitron, a bad plug or plug wire, an improper gap setting between magnitron and magnet, or a bad magnet (which would not fire either magnitron).
I would also be suspect of the part you bought from Amazon.com. Even though it looks the same, it may not be to the same specs as the part supplied by Sonex.
Users browsing this forum: Google Adsense [Bot] and 35 guests
