Prince Propeller
Prince Propeller
Postby wlarson861 » Tue Jun 03, 2014 11:00 am
I have been a Prince propeller owner since I built my plane. Today I am convinced that they are the right choice for me. I had my center hinge pin from my cowl vibrate forward into the propeller and depart the aircraft which caused some damage to the prop. I sent an e-mail to Prince describing the damage and asking what to do to repair it. A few minutes after I sent my E-mail I got a phone call from Lonnie Prince wanting to talk about the issue. I have his opinion as to how to do a field repair without sending the prop in to the factory which means about a $10 cost and little down time. I think everyone should consider that Prince aircraft is working for our best interests. Even though Sonex doesn't list them as a viable company I will always think them to be superior to the other brand. High rpm static does not always equal fast blast off and climb!! My Prince P-Tip has always performed well.
Bill Larson
N861SX
wlarson861
Re: Prince Propeller
Postby vigilant104 » Tue Jun 03, 2014 11:55 am
It was great that Lonnie Prince took time to attend the American Sonex Association fly-in at Crossville last year, he gave a very informative presentation on prop carving. And he donated a brand-new prop to be raffled off to support the ASA. He's obviously a big supporter of Sonex builders, and a good guy. I know several people flying with Prince P-Tip props, and they like 'em.
Mark Waldron
Aerovee, Trigear
vigilant104
Postby MichaelFarley56 » Tue Jun 03, 2014 2:46 pm
Glad to hear your story Bill. I've been very happy with my P-Tip as well!
Waiex #0056 - N569KM (sold)
Onex #245
Postby falvarez » Tue Jun 03, 2014 3:57 pm
I am about ready to order my propeller and I am planning to go with the P-Tip. Lonnie was really pushing the carbon fiber prop vs wood. Please let me know your thoughts if the carbon is worth the extra cost.
Frank Alvarez
Sonex #800, Aerovee 2.1
falvarez
Postby wlarson861 » Tue Jun 03, 2014 11:32 pm
Mine has the composite cover and today it probably saved the prop. The dings in the coating are repairable, I don't know about how well unprotected wood would have fared.
Bill Larson
N861SX
wlarson861
Postby MichaelFarley56 » Wed Jun 04, 2014 10:42 am
Personally, I like the looks of the carbon cover and I appreciate the optional leading edge protection you can add to the prop. I don't think cost is that different. If you're going to use your plane to actually travel some, the extra protection will probably pay for itself if you ever fly through any rain. Our engines turn fast enough that unprotected wood props can be damaged quickly in heavy rain.
Onex #245
Postby vigilant104 » Wed Jun 04, 2014 11:01 am
wlarson861 wrote:Mine has the composite cover and today it probably saved the prop. The dings in the coating are repairable, I don't know about how well unprotected wood would have fared.
Bill,
Glad to hear that the prop is okay, that's a big deal. But, inquiring minds want to know: Were you able to find and repair the hinge pin? ;)
Mark
Mark Waldron
Aerovee, Trigear
vigilant104
Postby wlarson861 » Wed Jun 04, 2014 11:15 pm
Didn't even look for the hinge pin. It should be in the grass somewhere on the approach. Bought new music wire at the hardware store and will fab a new one, this time with a restraint attached to the cowl.
Bill Larson
N861SX
wlarson861
Postby N111YX » Thu Jun 05, 2014 8:35 am
Here's an easy way to secure the front hinge pin. Make a small "L" bend at the end then leave about two inches to float up and tuck under the cowl halves. It's a bit dufficult to see in the pic but it works for me!
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby radfordc » Thu Jun 05, 2014 8:49 am
I had a lower hinge pin slide forward and into the back of my Sensenich prop. I left a small scratch in the rear face of the prop but the damage wasn't significant. I now insert the lower pin from the rear of the cowl.
radfordc
Users browsing this forum: Google Adsense [Bot] and 73 guests
