by mike.smith » Mon May 26, 2014 7:04 pm
I received my airworthiness certificate yesterday on Sonex #439 (plans-built) - yay!
The only comment/question my DAR had was about how the standard Sonex elevator trim tab cable was attached to the trim tab. The plans just call for a "z-bend" in the wire. What we found is the cable can actually go through the hole (further up the cable; not in the direction of detaching from the tab) if the trim tab gets enough force on it. That puts the trim tab in a full-down position, that will not clear itself. I have to agree it's a tenuous connection.
Has anyone done something different? I'm cognizant that we don't want to be adding a bunch of weight to the trim tab.
