Sonex tail wheel assembly question
Postby Sonex1517 » Sat May 24, 2014 2:44 pm
I have the new Sonex tailwheel and assembly.
On plans page SNX-L03, detail -01 Tail Wheel installation.
I am trying to figure out how to accurately drill the hole in the pivot fitting for the tailwheel spring...I bought a drill jig for tubing - worked great on the titanium spring.
But this piece has an odd shaped tube.
Has anyone conquered this challenge?
The hole must be 1 1/12" down from the top of the tube neck, and at exactly 90 degrees through the spring...per plans....
(edited for clarity)
Chicagoland
N1517S reserved
Re: Sonex tail wheel assembly question
Postby Bryan Cotton » Sun May 25, 2014 8:08 am
Robbie,
You are way ahead of me but here are my musings on that tube. Measure the diameter of the circular part with a mic. Then you can calculate the circumference of the circle. Use a strip of paper to wrap around the odd shape and mark the apex on both ends of the paper. Fold in half with the apex marks lined up and the fold is the front of the tube. Measure 1/4 circumference from the front to spot your holes. Pilot them individually then jig it up in the drill press.
If I misunderstood and you have to drill through the hump then get a pipe drilling jig.
http://www.aircraftspruce.com/catalog/t ... ey=1139725
It's almost too easy.
Postby Sonex1517 » Sun May 25, 2014 8:36 pm
I got the thing drilled today with the help of a friend. Not sure why it comes assembled, as you must disassemble it to drill it....
Chicagoland
N1517S reserved
Postby Sonex1517 » Sun May 25, 2014 8:37 pm
Bryan
Thanks - your suggestion worked.
Chicagoland
N1517S reserved
Postby Sonex1517 » Tue May 27, 2014 9:22 pm
I completed drilling the tailwheel assembly in place today.
I disassembled the tailwheel from the pivot assembly, and clamped it up in a small vise. I used a small pilot drill this past weekend to make a starter hole in the tube where the tailwheel spring slides in, and marked on the titanium spring with a red sharpie how deep it had to be so I knew it was set in place
Today I mounted the tailwheel bracket in place and set the angle for the tailwheel, then marked the spot on the titanium tailwheel spring with the pilot bit.
I then disassembled it again, put it back on the drill press and updrilled the whole thing in separate steps.
Worked out great and came out very nicely.
Chicagoland
N1517S reserved
Postby Bryan Cotton » Tue May 27, 2014 9:25 pm
Looks good Robbie! I can't wait to get the Waiex on the gear.
Postby Sonex1517 » Tue May 27, 2014 9:49 pm
Bryan, thanks!
With a little luck mine should be on the gear by the end of the weekend....off work this week and on a mission.
Engine kit should ship this week also.
Chicagoland
N1517S reserved
Postby fastj22 » Tue May 27, 2014 9:57 pm
The new Sonex tailwheel assembly sure looks great.
Users browsing this forum: No registered users and 47 guests
