vigilant104 wrote: For various reasons (a torrential downpour/hailstorm on the roof of my tin hangar) it wasn't possible to listen and tell where the air was leaking to.
Opinions?
A differential compression test doesn't really tell you much until you determine where the leak is. I'd redo the test on that cylinder when you can listen for the leak. If it's rings (air coming out of the crankcase vent) I wouldn't worry about it much, as it is probably fine when the engine is hot. You can recheck it in a few hours after doing a lot of flying and it will probably show an increase. If the leak is through a valve, it's important to know which one. Most often it's an exhaust valve, but on a rare occasion an intake valve will leak.
Someone else mentioned "staking" the leaking valve. I've had this help exactly once in my entire career, but there's always that chance. In order to do it right you need two people and your differential compression tester. Hook up your tester, then have someone hold the prop at a point where the piston is about halfway up on the compression stroke. Then put about 20 lbs of air pressure into the cylinder with your compression tester. While the pressure is on and your partner is holding the prop, give the valve a couple of good raps with a soft mallet. You'll hear a nice "pop" as the valve opens and snaps shut. If there is a piece of foreign material on the valve seat, this should blow it out. Like I said, not real likely, but doesn't take a lot of effort so worth the try.
Also, if you or someone you know has a borescope with a 90 degree mirror attachment, and you or they know what to look for, you can borescope the cylinder and look at the valves without pulling the head. This will only show something if it's a very obvious problem though, and with your level of leakage I doubt you'll see anything too untoward.
Again, it's important to determine for sure what's leaking and how much before going forward with any repair strategy (if deemed necessary).
