Rudder drive horn - bushings?
Postby Gunther » Tue May 20, 2014 11:58 pm
Hello to all. I just noticed that the rudder drive horn is controlled via two 3/16" bolts. Has anyone considered pressing thin bushings in the holes to prevent wear of the 3/16" aluminum drive horn?
I haven't checked the edge distance of the part to verify if there's room to drill 1/4 instead of 3/16 for a bushing.
Gunther
Tri-gear Sonex, Turbo AeroVee, dual controls, 70% complete
Gunther
Re: Rudder drive horn - bushings?
Postby tonyr » Wed May 21, 2014 12:34 am
Guther,
Re: bushings - No not that I am aware of, no need really as there is not much load on the rudder cables in flight.
Rule #1 - build first to plans - modify later.. if only I had stuck to that rule!
Cheers
Tony
Sonex #813
First Flight... 4 Oct 14
298 hours having fun!
tonyr
Postby Fastcapy » Wed May 21, 2014 7:43 am
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Users browsing this forum: No registered users and 67 guests
