by fastj22 » Tue May 20, 2014 9:49 pm
I was looking through my MGL xTreme manual tonight and noticed you can setup a virtual fuel tank. You just set the total capacity and use a fuel flow sender to keep track of the level. After you fill up, reset the gauge. I also thought of marking the tank with a sharpie at critical levels and installing a mommy mirror under the panel to view it.
The Belite sender is intriguing though. Looks like you calibrate it empty and full to get your voltage range, then calibrate your gauge using different fill levels. They say you need to recalibrate when switching between avgas and mogas because the specific gravity is different but its impervious to ethanol. recalibrating between fuels is kinda a pain. A quick google showed MoGas specific gravity is 0.739 @60F and AvGas is 0.68-0.74 @60F
