Battery Box for tail dragger problem
Re: Battery Box for tail dragger problem
Postby mike.smith » Fri Mar 28, 2014 7:00 pm
sonex1284 wrote:Roy,
I made the side of mine removable so that it would slide out like this:
See the 3 pictures in a row.
http://picasaweb.google.com/Sonex1284/S ... 4135557106
http://picasaweb.google.com/Sonex1284/1 ... 8896932018
Mike #1284
That's what I did, too.
Mike (the other Mike) :-)
Postby onex0127 » Fri Mar 28, 2014 8:48 pm
Hay all: Again thanks much for the help.
Roy Taylor
onex0127
Postby onexpilot » Sat Mar 29, 2014 10:41 pm
That's a good idea! We figure we are going to have to cut the battery out when the time comes
Derek Hodges
Onex #0056
N491NX
Conventional Gear/Aerovee 2.1
Hobbs 118 hrs - KTPL Temple, Texas
onexpilot
Postby onex0127 » Mon Mar 31, 2014 9:38 am
new battery box 2.jpg (463.45 KiB) Viewed 4419 times
new battery box 1.jpg (468.13 KiB) Viewed 4419 times
Just wanted to show you how it turned out. It worked.
onex0127
Postby dallen » Tue Apr 01, 2014 10:22 am
Had the same problem with my plane. What I did was drill the rivets out on the outside vertical and install nutserts and screws. I can get the battery out on the side.
dallen
Postby Forester818 » Fri May 16, 2014 4:01 pm
I've read the battery box posts, but can't find reference to this: I built the box to the plans but found the bottom of the box came out 1/2" too short; also, it appears on initial fitting that the longer sides make it impossible to fit the box on the designated firewall position and have it clear the engine mount.
Should the whole thing be built to conform to the shorter bottom panel; I found no plan amendment, so appreciate any feedback.
Bud Taylor
Tulare, CA
Forester818
Postby onex0127 » Sat May 17, 2014 10:25 am
Hey Bud: I ended up just taking the demolitions off the battery and adding 1/8" . The first battery box I built did not work. If you want to call me I can walk you through what I did.
410-391-3131
Roy Taylor
Baltimore
onex0127
