aganjoo wrote:Thanks for your inputs Dale
I have tried multiple headsets with electret mic. Do you know how to check/change the microphone gain settings on the radio. I cannot seem to find the details on that
Hi Amit,
I was afraid you'd ask that. Before changing headsets my radio was picking up too much through the mic and I wanted to turn my mic gain down. I called a dealer but don't recall who and where they were.
From my old and failing memory I *think* the information he gave me was that the component was labeled "RM06" and was located near the right rear side of the radio. I never took the cover off of my radio as using the the Clarity Aloft headsets cured the concerns I had with the hot mic.
I truly would doubt that the mic gain is the concern. I would tend more to think that you have either an antenna with a very high SWR, or (worse case scenario) the final output transistors in the radio have been damaged by keying the radio up without a load on it. In my case I have a friend that has the equipment to check both the antenna SWR (Standing Wave Ratio) and the wattage/modulation of the radio output. The radio, as sent from the factory, is set to be quite impressive both on power and modulation.
I wouldn't open the radio until all other options have been exhausted.
Dale
N319WF
