Sonex Fuel Tank
Re: Sonex Fuel Tank
Postby chrisyk » Mon May 05, 2014 8:57 pm
Re inspection camera. You can buy a cheapy on ebay for around $20.00 I have one and it actually works. Most of them are 640x480 but I bought a 1280x720 for $25.00. This is perfect for a job like looking in a (empty) fuel tank. I haven't tried yet but it might work for inspecting valves through the spark plug hole. These inexpensive ones plug into your USB port on a computer, and use the computer screen.
Look under "endoscope" on Ebay.
chrisyk
Re: Sonex Fuel Tank
Postby Don_P » Thu May 08, 2014 9:38 pm
I've been following this thread to see if anyone would comment on pipe-thread fittings in the fuel system. Haven't seen any, so here goes: I'm plumbing a Onex (0095), and several of the fuel-system fittings are NPT, such as the finger stainer and the fuel shut-off valve. I understand that the general rule of thumb for screwing in an NPT fitting is to get it finger tight, then snug it up with a wrench, but making only about one and a half or two turns. When I do this, I can get the male end to go in only about three or four turns, which puts the fitting in only half way. I'm concerned that this will not make for a good, no-leak seal. Where possible, like the female fittings in the tank, I've run a pipe tap through the fitting (as per Sonex instructions), and this solves the problem, but this is not always possible, as in the case of the fuel cut-off valve, where the tap immediately bottoms out in the fitting before doing any serious cutting. Is an NPT fitting with only half the treads engaged an acceptable practice?
Don
Onex 0095
N464D (reserved)
Don_P
Re: Sonex Fuel Tank
Postby EricS » Sat May 10, 2014 10:36 pm
Hi Don, I understand exactly what you are talking about because I was working on my tank-to-firewall plumbing today. The fit is tight and I think you will have better luck if you put some fuel lube on the threads of all the fittings. I use the EZ Turn Lubricant that Joe was referring to earlier. It works great as a gasket/sealant, won't harm the fuel system, and helps you get better thread insertion.
Here's the link to the product on Aircraft Spruce's site: http://www.aircraftspruce.com/catalog/cspages/ezturnlube.php
Let us know how you make out!
Eric Seber
Waiex #153
Jasper, Indiana
http://www.mykitlog.com/EricS/
EricS
Re: Sonex Fuel Tank
Postby Don_P » Sun May 11, 2014 10:08 am
Thanks Eric. I'll get a tube of this and try it out.
Don
Onex 0095
N464D (reserved)
Don_P
Users browsing this forum: No registered users and 77 guests
