About 2 years ago AVEX changed some dimensions on their rivets, making the
head bigger. We changed the 120 degree dimple dies from the old dimensions
(smaller / thinner rivet head) to the newer larger / thicker rivet head at
that time. You will need the newer version dimple dies for the new style
rivets. If for some reason that does not work, I can get some of the
rivets from you and machine a set of dies to fit your rivets.
Bob Avery
-----Original Message-----
Sent: Thursday, October 03, 2013 12:01 PM
To: boba@averytools.com
Subject: 120 dimple die question
Bob,
Years ago I bought an Avery 120 dimple die for avex rivets. My Sonex uses
some CCC-42 and other size flush pull rivets. The heads seem bigger than the
avex rivets. When I pull them they are not quite flush. Do you have a
version for these rivets?
Bryan
leeforshee wrote:Does anyone know for certain if the ccc42 rivets are stronger or weaker than an426
(if my math is right? used to be good at that stuff but that was 45 years ago) 26000 psi devided by 64 = 406 and 38000 devided by 64 = 593. Mine is a little different than yours, anyone have a different answer?
Users browsing this forum: No registered users and 98 guests
