Fuel shut off valve
Fuel shut off valve
Postby Sonex1517 » Thu May 01, 2014 9:09 pm
Hi everyone
Does anyone have a specific part number for the fuel shut off valve?
The plans state to use a 1/4" pipe thread brass close union valve, and my searching has not made me believe I have a specific part number yet.
Anyone have something that they used? I am thinking to put in a fuel shut off handle on the instrument panel, but not certain yet. So I am looking for a valve that makes this possible.....
Chicagoland
N1517S reserved
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Re: Fuel shut off valve
Postby tonyr » Thu May 01, 2014 9:23 pm
Hi Robbie,
I used one of these from Wicks, as provided in one of the Sonex hardware kits... FV-107401
http://aircraftproducts.wicksaircraft.c ... d&filter=0
Cheers
Tony
Sonex #813
First Flight... 4 Oct 14
298 hours having fun!
tonyr
Fuel shut off valve
Postby Sonex1517 » Thu May 01, 2014 9:34 pm
Thanks Tony!
Chicagoland
N1517S reserved
Aero Estates (T25)
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby N1906R » Thu May 01, 2014 9:38 pm
Thats what I used as well
Jim Reichard
Sonex814
N1906R
3300 Jab
Standard Gear
N1906R
Postby hickej » Thu May 01, 2014 11:56 pm
Here is a picture of my fuel shut-off handle. I made a bracket under the panel with a snap bushing that the rod goes through and then I screwed on a handle made from a piece of aluminum. My DAR (and other pilot buddies) strongly suggested installing a panel mounted handle and I am very glad that I did. Of course my DAR had me put a label on it as well:
FUEL
Push-ON
Pull-OFF
It's a little hard to see since the blue tape is wrapped around the shutoff valve and fittings but you'll get the idea.
http://www.n716wx.hicke.com/index.php/uploads/Waiex-Builders-Log/FuelTankMain/P1010261
hickej
Postby mike.smith » Fri May 02, 2014 1:07 am
hickej wrote:Here is a picture of my fuel shut-off handle. I made a bracket under the panel with a snap bushing that the rod goes through and then I screwed on a handle made from a piece of aluminum. My DAR (and other pilot buddies) strongly suggested installing a panel mounted handle and I am very glad that I did. Of course my DAR had me put a label on it as well:
FUEL
Push-ON
Pull-OFF
I did a similar thing:
http://www.mykitlog.com/users/display_l ... 979&row=10
The fuel valve is on/open when the handle is pushed in against the instrument panel, so it's out of the way. When the airplane is shut down the handle is pulled out as shown in the photo. With this you always know the status of the fuel valve at a glance.
When starting and shutting down, I LOVE having a panel mounted shut-off!
Mike
Sonex #439
(2-3 weeks from inspection)
Postby n982sx » Fri May 02, 2014 10:55 am
I would add to the chorus, that having a fuel shut off valve on the panel is well worth the effort.
Mine is a slightly modified version of Bob Mika's.
Close up of the modified fuel valve...
http://n982sx.com/sonexlog138/index9.html
Close up of the control rod at the panel...
http://n982sx.com/sonexlog139/index9.html
The handle was eventually dipped in a red plastic coating.
Bob Meyers
Built and Flying Sonex N982SX http://n982sx.com
Built and Flying RV-14 N626KM http://n626km.com
n982sx
Return to Sonex
Users browsing this forum: No registered users and 51 guests
