Routing cables through firewall
Postby gammaxy » Wed Apr 30, 2014 11:17 pm
What technique is everyone using to route throttle and mixture cables through the firewall?
I have been trying to decide between the Cable Safe and Eyeball assemblies. Which is best for passing through the angled firewall?
What about a simple rubber grommet?
Re: Routing cables through firewall
Postby rizzz » Thu May 01, 2014 12:54 am
gammaxy wrote:What about a simple rubber grommet?
That's all I'm doing.
Postby Rick524 » Thu May 01, 2014 1:14 am
I used this. All the wires fit and it seems like it will be ok.
http://www.aircraftspruce.ca/catalog/el ... _kit34.php
Rick
Sonex 524
Rick524
Postby mike.smith » Thu May 01, 2014 8:07 am
gammaxy wrote:What technique is everyone using to route throttle and mixture cables through the firewall?
I used these stainless steel shields (A/C Spruce) that have a fire gasket (red) on the back side. I added a little fire caulk as well, just to make sure the gap between the shield and the firewall was filled.
http://www.mykitlog.com/users/display_l ... 892&row=11
http://www.mykitlog.com/users/display_l ... 9721&row=1
Mike
Sonex #439
Postby sonex1284 » Thu May 01, 2014 2:50 pm
I used a concept (almost a trick) that I picked up reading Tony Bingelis' book Firewall Forward. I applied RTV to the small remaining gaps. It worked for me!
Photos 4-10
https://picasaweb.google.com/Sonex1284/June252011
Photos 5-8
https://picasaweb.google.com/Sonex1284/July32011
Mike #1284
Mike Kelley
The Villages, FL 32163
Sonex 1284, N154MK, Tri-Gear w/Jab 3300
sonex1284
Postby MichaelFarley56 » Thu May 01, 2014 6:13 pm
I used Aircraft Spruce Cable Safe II firewall cable fittings. I can't remember which size the cables are, but the part numbers from ACS is either 05-16252 or 05-16253.
They work great!
Users browsing this forum: No registered users and 105 guests
