Rynoth wrote:Those rivets should have only cost a couple bucks, $20.90 sounds way high. You sure 20.90 isn't the per-pound price?
I asked Sonex about alternate methods for these fasteners and they had none. The rivets as called in the plans in all they recommend.
rizzz wrote:You'll need 6 of these rivets on the spar tunnel, that's it. I guess .13lbs is the minimum quantity you can get.
Have a look at drawing F02 (I believe it is), you'll see these rivets are the outer top rivets on the spar tunnel (3 on each side).
The reason they are solid is because they will need to be bucked flush in the spar tunnel to avoid interference with the spars. The seat pan will rest on top of the factory heads.
Darick wrote:I still don't get it. Why is it necessary to these when all the other rivets inside the spar tunnel use CCC flush rivets? Unless it is for the higher strength of solid rivets.
Users browsing this forum: No registered users and 68 guests
