I got the airplane into the back yard today with the help of Howard Linker and Al Lavender we rolled it into my back yard. The AeroVee started up on the first try with no hesitations and ran great.
After running it we put the wings on so I can spend time trimming and installing the wing root doublers, and making sure all the controls will link up.
it looks and sounds great Mike! you are definitely getting close to the first flight! Did you paint the front of your turtle deck before or after you assembled it?
Vic Delgado Sonex "CorVex" #969 Plans 3.0L Corvair, tail dragger, single stick Houston, TX Expercraft Builders Log complete: tail,wings, welded & angle parts "Old Corvairs never die, They just earn their wings".
Bryan Cotton Poplar Grove, IL C77 Waiex 191 N191YX Taildragger, Aerovee, acro ailerons dual sticks with sport trainer controls Prebuilt spars and machined angle kit Year 2 flying and approaching 200 hours December 23
vicdelgado9 wrote:it looks and sounds great Mike! you are definitely getting close to the first flight! Did you paint the front of your turtle deck before or after you assembled it?
Before. I painted the formers and then installed them. I also painted the rear canopy frames so that they will blend in with the red formers behind. Canopy was off for first start and wing install.
