by Mike53 » Fri Jul 26, 2013 2:16 pm
If you have a straight out exit from your basement where you don't have to negotiate any turns you will be able to assemble the forward and rear fuse with the turtle deck and join them together.Your spars and wings are also not a problem but you will have to wait till you move to bigger quarters before you can put the spar through and attach it.Otherwise you can get a heck of a lot done in your basement.
I started mine in the basement but because it was not a straight out exit I could not join the fuses or attach the turtle deck.
Go for it!
Cheers ,
Mike, Onex 080
Mike
Antoine de Saint-Exupery
