Tigers2007 wrote:Gammaxy - you completed the $1700-1900 upgrade kit in just over 40 hours plus drill time??
I"ve completed probably 80% of all the angle components for my Waiex so far. I did not log the fabrication time specifically since I made them as I went, but there were a few times (main spar, fuselage side skins) where a lot of angle components had to be made and once, and I did essentially log the time exactly. Based on that and other parts, I'd say I've spent less than 60 hours making the parts so far. A safe guess for me to do them all is probably less than 80 hours.
The second half parts I made took probably 3-4x less time than the first half, just after learning the best techniques to do it. At this point I can make pretty much any part from angle, cut/drilled/deburred and ready to go in under 30 minutes. I've had to scrap probably half a dozen parts so far, but it appears I still have enough angle in the kit to finish without needing to order more.
I know the Onex has more of these parts, but 2000 hours is ludicrous. Even 200 hours is pretty darned slow.
