Right wing counterweight rubbing aft rib
Postby Bryan Cotton » Tue Feb 18, 2025 10:48 pm
Annual time. We had developed a slight rub detectable during preflight when moving the right aileron. Opened it up and found this:
We had a slight rub when building. Not that I remember that far back but the lettering had been sanded off the most forward counterweight bolt. After my discovery I sanded them all down some and polished out those gouges.
The rib flanges all face left, so there is a lot of room on the left counterweight.
If you are building I would sand down all those bolt heads some - for sure take the raised lettering off. Something to look at during annual for the veterans.
Re: Right wing counterweight rubbing aft rib
Postby Murray Parr » Wed Feb 19, 2025 2:57 am
Mine rub too. I shaved off the bolt head as much as I was comfortable, and it still rubs if I pull the aileron towards the rib on preflight. I think I will replace the bolts with countersunk bolts to fix it. maybe something you could consider too.
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
First flight May 6/23
RV9 builder (Sold)
Murray Parr
Postby N111YX » Fri Feb 21, 2025 1:22 pm
I think that this has been an issue for many before.
I did indeed use countersunk machine screws of the same diameter of the bolts. If you look at the load specs of the screws, you'll have more serious issues if you break them in that lead.
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Return to Safety and Training
