bvolcko38 wrote:What about a ceramic bearing?
I am not convinced that this will solve his problem.
As I understand the issue, luboil is leaking past his shaft seal rings (small piston rings). Some oil will unavoidedly leak past them, driven by the bearing luboil pressure, no matter how good they are or whatever you do. When this oil comes in contact with the white hot exhaust gases in the turbine housing, the lubricant turns into carbon. Sooner or later the rings cease to seal.
Imho the overall design of the turbo bearing housing needs to be revised.
Sonex A #0525- SG, DS.
