Rynoth wrote: I like the idea of not having to cut a big hole in the firewall and fabricate heat muffs and piping for cabin heat.
vigilant104 wrote:Mike,
Thanks for the post and the pictures. That looks like a clean setup. I look forward to hearing how it actually performs (temp rise of air coming into the cabin and how much air there is--ultimately how much warmer does it get inside the airplane vs no heater).
Some questions:
- For the valve on the firewall: SS or aluminum? I know we all want to keep any "fire" on the correct side of the "wall."
- Have you decided where you'll get the air feed from? I've seen some nice scoops added to the cowling for this, but I'd like to avoid having another thing to be disconnected when I remove the cowl, and I'd like to avoid the drag of another opening. I like Mike F's suggestion of tapping into the air right at the opening of the oil cooler duct, I'll need to take a look next time I'm at the plane and see if there's room there. I've got a slightly leaky main bearing seal, I'd need to keep any wayward oil out of the heater (or, heaven forbid, fix the seal!).
Thanks again.
hickej wrote:My heat muff has proven to be too small. It keeps me comfortable down to around 50F at night. I had to seal the canopy to keep air out. I may be able to go lower once I seal the air leaks coming in through the wing root. I am looking for a larger area for another heat muff but it is a tight fit. I am going to add a second heat muff to the other 3to1 exhaust to double my heat output and see what happens. I'll post more when I have more data.
