Panther16 wrote:Aircraft electrical connections are no place for auto zone, especially the hi current alternator leads. Use faston stud type terminals and bolt together or use a stud type terminal strip. If bolting together cover with shrink tubing but do not shrink to allow for cooling of the joint.
DCASonex wrote:Saw a report here many years ago of someone who had a VR burn through the thin SS firewall, and with the fuel tank right behind that, I mounted mine on a slightly heavier piece of SS, hat shaped for about 1/2" clearance. It is big enough to hold a small relay and a filter capacitor. Best cooling of the VR will be with its fins oriented vertically.
Markmb2 wrote:I have just fitted the VR suggested by Jeff and all seems OK apart from my tacho now reads massively over once the Alternator kicks in. I have an Aerovee, MGL Discovery Lite iEFIS and an RADC XF. The feed tacho feed is from the VR and I have added a wire from the IGN terminal on the VR to the Master Solenoid. All the other wiring is as is.
For info, the reason why I fitted the Caltric VR was to try to get a better charge from my Odessey 625 battery as the standard 3 pin unit doesn't seem to cut it. Basically with both Primary and Secondary ignitions on, and Rpm below 2000 I'm getting Low Voltage Massages on the iEFIS and my radio transmission are clipped due to insufficient volt / amp. The Battery is new and fully charged on a trickle charger in my hangar.
Any advice please.
Regards
Mark
