Mike53 wrote:Anyone with a Zenith carb install a temp probe into the upper throat of the carb?
Any reasons not to?
There is a brass plug just above the butterfly that could conceivably be drilled and tapped to fit the probe. I had a carb ice event last summer and would like to be pro -active on preventing another episode.
Mike
Best prevention is to;
Always apply carburettor heat BEFORE you reduce power.
Keep tabs on the weather forecast for humidity & temperature - apply your training - what are the chances of carb ice?
