Brake & Wheel Pants Mount Damage
Re: Brake & Wheel Pants Mount Damage
Postby Hambone » Wed Jan 15, 2025 11:48 pm
Bryan Cotton wrote:I've made some thin aluminum shims to take up the slop in the axle and get it just right.
Is this more a less a thin washer with the inside diameter the same as the axle diameter? I guess it would have to be very thin. It seems the best position for the axle nut is exactly between two holes in the axle, so the washer would have to be 1/12 of a thread thick. I'm not sure what the axle threads per inch are, but if it's 12, then the shim would have to be 1/144" (.006944"). That's pretty thin!
I suppose it could be an odd multiple of .006944", too (like 1/16").
Hambone
Postby Bryan Cotton » Wed Jan 15, 2025 11:53 pm
Hambone wrote:Is this more a less a thin washer with the inside diameter the same as the axle diameter? I guess it would have to be very thin. It seems the best position for the axle nut is exactly between two holes in the axle, so the washer would have to be 1/12 of a thread. I'm not sure what the axle threads per inch, but if it's 12, then the shim would have to be 1/144" (.007"). That's pretty thin!
Yes, basically a washer. Not as critical as you are thinking - a normal thin washer plus turning it out another castellation or two may get you what you need.
Postby Hambone » Wed Jan 15, 2025 11:56 pm
Maybe taxiing it around a bit will loosen it up. If it's still tight, I'll try the washer fix. Thanks!
Hambone
Postby WaiexN143NM » Fri Jan 17, 2025 3:04 pm
Hi all,
Here is some more update to tracy obrien parts for sonex. He emailed me this am, and wanted me to share with you. His website went out last summer.
QuinnG. you may be able to help him out.
Tracy is now living in yuma az.
He may start advertizing on barnstormers.
parts he offers:
C-90 brakes and parts
chromoly landing gear legs for td and tri gear.
chromoly motor mounts td and tri for legacy jab3300
2in axle torque plates.
tracey said to email Steve@super-12.com
he has the parts in stock.
tracy obrien. email contact. tracy@localaccess.com
i hope this helps out- its a start.
best,
michael.
Users browsing this forum: Bing [Bot] and 5 guests
