flyinbrian wrote:It was obvious to me that this was the weakest part of airplane. I welded a plate with room for 3 AN3 bolts on mine
Hambone wrote:Bryan - do you mean have them weld the piece on, then I drill the holes? I’m trying to avoid disconnecting the hydraulic line.
Hambone wrote:It should! I’m sure I’ll find something ride to break next.
Putting one wheel on, it had to be too loose or too tight to get the cotter pin through the axle. I had no choice but to make it too tight. Perhaps it will loosen up with use.
