98% complete and 98% to go in Northern California
Re: 98% complete and 98% to go in Northern California
Postby karmarepair » Fri Jul 22, 2022 10:07 pm
BRS wrote:If you convert to SDS would it be just for the ignition or would you install injection as well?
How much current does your alternator put out?
Ignition only.
I have the 20 amp alternator.
karmarepair
Postby karmarepair » Mon Nov 07, 2022 2:24 am
A little progress on the fuel vent/door and the new canopy latch, plus registration. https://eaabuilderslog.org/?blproject&proj=7fZQxebwn
Getting "Time In Type" continues to be a problem. A recent trip from California to Missouri in hopes of getting transition training did not pan out. And my present weight (230# in street clothes) limits who is willing to fly with me. So I started Noom and I will get below 200. And I extracted contact information for every Sonex/Waiex in California from the FAA registration database.
karmarepair
Postby karmarepair » Sun Mar 26, 2023 1:28 am
More progress, revised the brakes https://eaabuilderslog.org/?s=wlawrence
If you have a Legacy Sonex with mechanical brakes, work on improving them before going hydraulic. I tacked 50 grit sandpaper inside the drums of the Azusas on my Sonerai and slowly tightened them while spinning the tires, to get full contact between the drums and the shoes. A previous builder put a section of hard line adjacent the brakes, for heat resistance, which added a bunch of fittings to leak air. Plus, the garden sprayer turned pressure bleeder I borrowed aerates the fluid. We had a devil of a time bleeding the brakes when this was a Chapter project and had toe brakes. Air got in somehow after the clare shield was riveted down, which I didn't discover till I pulled the tank to re-route the throttle.
karmarepair
Postby karmarepair » Sun May 14, 2023 2:27 pm
Got the engine running for the first time since I took over the project.
Curtis Valve on the gascolator leaked so bad it was leaning out the carb, which I've been tweaking per Jeff Schultz's suggestions http://www.sonex604.com/aerocarb_thoughts.html
Finally got the brakes bled, and they work GREAT. I love the parking brake valve.
Just like the previous toilers on this project, I could NOT get the magnetron ignition to work, and I'm pulling it off to replace it with a Simple Digital System Coil Pack ignition. I've started to work up the bracketry I'll need to mount the Hall Effect sensors for the crank trigger. I've been planning this since BEFORE I bought the project, but wanted to give the Magnetrons ONE MORE CHANCE, and they failed.
Progress and pictures at http://eaabuilderslog.org/?s=wlawrence
The FAA paperwork for Certification is mocked up, but I'm waiting to get my medical Special Issuance back before I fire it off, plus I need to finish the Weight and Balance, so inspection and first flight are looking like September/October of this year.
karmarepair
Postby Bryan Cotton » Sun May 14, 2023 8:01 pm
Sorry to hear of your magnetron trouble. Mine have been great! Super simple system.
Postby karmarepair » Sun Sep 22, 2024 3:21 pm
https://eaabuilderslog.org/?blproject&p ... n&add&sid=
It's been a while. I flew with Jeff Schultz last Fall, and wrote about it.
I got my medical straightened out.
SDS ignition is in, needs a timing check.
Pitot Static check done, but ADSB out is being weird.
I have a liability only insurance quote of 1300/YR.
Getting really close. Main need now is solo hours so that I feel airworthy.
karmarepair
Postby Bryan Cotton » Tue Sep 24, 2024 4:33 pm
Do you have two electronic ignitions?
Postby karmarepair » Tue Sep 24, 2024 9:14 pm
Bryan Cotton wrote:Do you have two electronic ignitions?
Yes.
Not a path I recommend.
We fired the parts cannon several times at this engine and the primary ignition never worked right.
I think now the flywheel was the problem. It was not changed.
karmarepair
Postby karmarepair » Sun Jan 12, 2025 12:54 am
Yesterday, I got my Airworthiness Certificate.
Today, I changed from a 2.5 to a 2 needle to richen the mixture off full throttle. I'm using an Air Fuel Ratio Meter to tune and life is good; I'm almost exactly where I want to be. The SDS ignition is completely dialed in.
http://eaabuilderslog.org/?blprojentry& ... tcat=&sid= my AFR setup
http://eaabuilderslog.org/?blprojentry& ... tcat=&sid= Easy way to get a bung for the AFR sensor.
http://eaabuilderslog.org/?blproject&pr ... tcat=&sid= Our complete ignition journey. My current theory is the generational magnets on the flywheel were damaged at some time in the past. There is evidence the magnets were impacting the magnetrons - not on MY watch, but I'm not the OG on this joint. Hitting a magnet is a good way to de-magnetize it. I'm trying to figure out a way to test this theory. I may want to put the magnetrons back ON, and eliminate the factory secondary ignition, AFTER THE AIRPLANE FLIES!
karmarepair
Postby Bryan Cotton » Sun Jan 12, 2025 9:38 am
Congrats on the airworthiness certificate!
Return to Introductions
