Turbo rebuild
Turbo rebuild
Postby T41pilot » Fri Sep 09, 2022 4:24 pm
Has anyone out in Aerovee turbo land rebuilt or refurbished their turbo? My Turbo only has 8 hours on it and it is seized to the point it is unusable. I got the vanes to break loose, but it feels terrible with no spin capability. No amount of fogging or rust spray has freed it up further. My guess it is coked up inside. I have the turbo cooling system plumbed in and used it after each flight. I only have 5 flights on the plane so far. There is a turbo shop within a 45 minute drive from me that can probably get it refurbished but average cost is 400 to 500 bucks. Don't know if this turbo falls in that range. Haven't talked to to them yet. Very frustrating to have to keep shelling out money for extra parts plumbing etc for such low time in service. I probably have the skills to get the turbo apart but in the brief reading on turbos I have done so far,it is indicated that it has to be balanced after servicing. I certainly don't have the skills or tools for that. So what are my options here?
Gregg Kaat
Sonex B #0014
T41pilot
Re: Turbo rebuild
Postby Onex107 » Sat Sep 10, 2022 9:06 am
Turbos are balanced at different harmonic frequencies by removing metal from the blades. It should not be necessary to rebalance after cleaning and replacing the bearings. My 2 cents. I witnessed a rebuild by a hangar neighbor. From what I read on turbo coking it occurs in the temp range of 400 to 800 degrees. Your cooling system should prevent temps that high. Check out your lube and cooling systems. Another friend has attached a thermocouple to the bearing housing and never sees temps over 300.
Re: Turbo rebuild
Postby T41pilot » Sat Sep 10, 2022 3:28 pm
Thanks onex107. My Turbo freed up overnight with left over fluid that I had not realized was still in it. I was convinced that I was going to take it in for service but now I may just let it soak some more for good measure. It doesn't spin like when it was new but spins about the same as the amount of my last flight that was successful. This is the second time it has acted up. The first time it failed, it freed up on its own during a run up when I had the plane tied down. There is a bearing kit that I can buy from speedyracer.com that is about 30 bucks. It is my understanding that this turbo is a TB2568 that fits a 4bd2 Isuzu engine. Let me know if I'm wrong. I'll soak some more and may try it and in the meantime order the bearing kit if it looks correct to a person in the know. Google tb2568 turbo repair kit for info.
Gregg Kaat
Sonex B #0014
T41pilot
Re: Turbo rebuild
Postby pfhoeycfi » Sun Sep 11, 2022 12:41 pm
Did you determine why the turbo was binding up? I'll just throw this out there in case it's cooling system related, but I couldn't get the cooling pump to prime by filling the system via the catch can...so even tho the catch can and system appeared full, it was not, and therefore not pumping. I put a fill tee in the pump suction line and that worked great for the initial fill.
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: Turbo rebuild
Postby Brett » Sun Sep 11, 2022 7:52 pm
When I needed bearing replaced in mine a few years ago I had the local turbo shop replace them. Cost me $80.
Sonex 1645
VH-VWS
Tailwheel
Former Aerovee Turbo
Rotax 912
Brett
Re: Turbo rebuild
Postby Onex107 » Mon Sep 12, 2022 10:34 am
My friend's Onex turbo cooling system had problems. He has had three water pump failures for different reasons. He found that the pump had to be at the bottom of the system, or it would not prime. When the radiator fan was running, he could not hear the water pump and did not know it had failed. If you lower the water level in the catch can below the return line you should be able to see the pump flow. His thermocouple attached to the top of the bearing housing does not show the actual temp at the shaft and bearings, but it is relative and will show you that the cooling system is working after shutoff. It seems that after shutoff the temp jumps about 50 degrees before the cooling system takes over and starts to reduce the temp.
Is your cooling system able to be turned on manually? It might be a good idea to turn it on while taxiing. The other thing I noticed on another Onex was a screened opening next to the cooling fan to admit outside air. The only air available behind the baffles is hot engine air.
Re: Turbo rebuild
Postby T41pilot » Mon Sep 12, 2022 4:41 pm
I found that my pump was intermittent during the course of the first 3 flights. The suggested connector didn't fit well and I modified it to work. So maybe I gunked the Turbo up to the point where it started to fail right off the bat. Plus a week sometimes 2 or more between flights as well as I troubleshot various problems probably didn't help. I didn't see rust caked on anything though. I install the coolant the same as you would bleed brakes by forcing it through with a squeeze bulb and exiting out the radiator into a bottle until no air shows. That seems to work well. I can turn it on manual to verify flow when done. I reinstalled the Turbo today as it loosened up nicely with some soaking and multiple shots of oil. I have to add the coolant yet. I have no doubt it will work for the next flight but for how long is what I'm interested in. If it fails again soon, I will have to consider other options.
Gregg Kaat
Sonex B #0014
T41pilot
Re: Turbo rebuild
Postby Sonex87AS » Wed Jan 08, 2025 12:32 am
I now have 35 hours on my Aerovee Turbo and have had 3 Turbo failures all of the same character. The turbo cartridge used by sonex is a Type: TB2547 and can be found on Turbo International website for under $400 you just have to use your exhaust and intake shells. My turbo didn't seize due to corrosion or oil burning ect. On the exhaust side just behind the turbine wheel is a small C ring or steel seal ring. This ring is designed to keep contaminants out as well as oil splash from exiting the sump on the hot side. When you pull the turbo apart you will see the ring is stuck and the gap is closed tightly around the shaft. No lubricants or spray will fix this. You have to pull the turbo apart to the point you can get the shaft out and service that ring so it moves freely. Each time my turbo failed I handled this ring differently with a slightly more positive result. This time I ran my exhaust turbine and shaft on a lath and polished it to a shine with a light steel wool and oil. The C ring or seal I ran on a very fine paper and some oil to clean it up and also take a slight bit of material away to allow a little more freedom for the ring to expand and contract. This time I am adding an anti-seize called Jet-Lube 550 Extreme to that ring area in hopes that this will either cure my issue and or give me some longevity between seizing events. I am ok with having this as a maintenance item every 50 hours or so but certainly not every 20. I have dealt with alot of headaches with this turbo set up and for the most part have about 98% of the bugs worked out except this particular issue. From what I can see is that soot is getting past the protective cover allowing foreign material to get into that sealing ring. To clarify my turbo in the air runs around 160 temp wise on the bearing block and if im pushing it 185. On the ground around 180 sometimes 200 F average till temps come down during the cool down cycle.
Sonex Turbo Failure.jpg (82.69 KiB) Viewed 289 times
Sonex87AS
Re: Turbo rebuild
Postby OneTallShort » Wed Jan 08, 2025 11:59 am
Thanks for your writeup of your turbo issue
Few questions with your setup.
A.) I don't see the external oil filter in your pictures. Do you have it installed?
B.) What fuel are your running in the engine?
C.) Is this with thr Brad Penn racing oil?
OneTallShort
Re: Turbo rebuild
Postby Sonex87AS » Thu Jan 09, 2025 3:45 pm
My oil filter is on the fire wall to the left as the manual depicts I can send you a picture of the set up if you would like. I use the Brad Penn 20W50 high zinc oil. My system holds just under 3 quarts. I run 100 LL as my build is a 7:1 compression ratio. I have tried using auto gas 93 octane and found no difference power wise. Also burns much cleaner. However the inconvenience is high as you cant fly around expecting to carry a jerry can ; ).
Sonex87AS
