SNX-C01 Detail C Control Triangle mounting (Sonex-A)
Re: SNX-C01 Detail C Control Triangle mounting (Sonex-A)
Postby ampzapper » Wed Jan 08, 2025 10:56 pm
Does the side with the SF-812-3 bushing allow the tab on the control stick frame to rotate freely? I haven’t quite got there but on mine the tab thickness with the powdercoat is 0.133” which seems like it would squeeze the tab so it couldn’t rotate when tightened down.
ampzapper
Postby Area 51% » Thu Jan 09, 2025 11:00 am
ampzapper wrote:Does the side with the SF-812-3 bushing allow the tab on the control stick frame to rotate freely? I haven’t quite got there but on mine the tab thickness with the powdercoat is 0.133” which seems like it would squeeze the tab so it couldn’t rotate when tightened down.
I carried this particular football about a month ago and you are correct.
I eliminated the powder coat in that area and gave it a shot of Rustoleum. Then I filed down the next longer size bushing for the prescribed clearance.
Area 51%
Return to Sonex Plans
