by BRS » Sat Jan 04, 2025 8:24 pm
Uncommanded down fault would be quite a stretch, though I guess possible. Putting the flaps down and having them stay down would be more likely. The good thing is, that the flaps don't go down unless I'm landing. The odd's that the flaps stick down and me doing a go-around/abort-landing would be worst case scenario. It would be most unlikely that I would do an abort the same day the flaps stuck down. Yes it could happen.
Comparing the sonex to a Cessna in this regard may not be quite fair. A more important question would be "Can the plane climb or at least maintain altitude with the flaps down. I don't know as I've not tried it but am certain to do so on my next flight (If I remember). Those of us with 80/85 HP might not be able to climb at all but those of you with 100 HP are likely to have better success. I'm wondering which Cessna's will climb with flaps. i know the Skyhawk (at least one model) will climb.
Story: Years ago I was in the back seat of a skyhawk (all seats full) to act as ballast for a student doing a gross weight checkout (I too was a student). The instructor called for a go-around which the pilot did but the plane was climbing very slowly and all on board was concerned. We got around the pattern with full flaps, landed and parked. Turns out a mechanic had left a wrench behind the panel and it jammed the flap mechanism, although the flap handle moved up nomally for the pilot.
-Brock
Sonex-A (s/n 1013), R2300, P-tip 54/50, Center Stick, V16, TT22
Sonex HW-QB#4
