I'm struggling trying to determine how to end up with the specified end play of .005" to .015" with the specified bearings and hardware.
The right side of SNX-C01 detail C shows a SF-812-3 which is 3/16" overall length (1/8" below the lip/ same thickness as the control triangle tab)
https://symmco.com/wp-content/uploads/P ... -812-3.pdfLeft side of detail shows a SF-812-4 which is 1/4" overall length, 3/16" below the lip, so 1/16" extension beyond the thickness of the control triangle tab.
https://symmco.com/wp-content/uploads/P ... -812-4.pdfSNX-F16-03 shows 16 1/2" between the angles
SXN-C05-02 has 8 1/8" both sides for 16 1/4" overall between the tabs.
So that leaves a 1/4" gap.
The specified AN960-416 washer is ~1/16" thick
The hardware as shown should take up 1/8" of gap with the -4 bearing and the washer.
That leaves the assembly with an extra 1/8" gap that isn't taken up per the plan shown hardware.
How have people been installing this?
A.) Use (2) SF-812-4 bearings and an AN960-416 washer on both sides?
B.) Use the bearings specified and (3) washers?
C.) Use (2) SF-812-5 bearings and no washers?
D.) Something else?
Gregg Short
Burbank, OH
Sonex-A #715
N715SX (Reserved)
