Skippydiesel wrote:I know that I need to move more air through my cowling BUT wish to keep the openings to the minimum required. In my mind this means locating them in a relativly low pressure zone, hence my interest in your reasoning for placing the louvers on the underside of the cowling.
Skippydiesel wrote:Dont forget your undercowl EBay temperatures.
My oil/coolant is sitting just where I want it, however my EBay is far too hot - got to over 40C with OAT 22C @ 2500ft, two days ago and regularly hit 60 C immediately after engine shut down - can't be god for electronics & fuel vaporisation/vapour block.
Have increased the size of my exit air and am in the process of refitting a cowl flap.
Kai wrote:Guys- you may be familiar with this installation?
When for the first time you put your hand on the cowling top of a recently run MCR 01 Ban Bi made by Dyn Aero in France, you will immediately pull it back because you reason something must be on fire in there: it is piping hot! Take off the top and you are presented with the view shown below: the muffler is sitting on top of the engine, just above the spot where the ignition modules should be. Should you have a feverish wish to permanently cook your engine electronics, this must surely be the way to go.
However, to keep the engine happy, the manufacturer has put in some remarkable development work: the engine must be supplied with cool ambient air (NOT from the cooking engine room!), which is drawn from outside the cowling through the white squarish inlet box shown on top in the picture. The ignition modules have been removed from their original position, supplied with extension wiring, and are now sitting low down on the firewall where of course it is much cooler. Finally, every (!) fuel line in the engine room has been fire sleeved.
The free space under the engine created by relocating the exhaust system is now occupied by coolant- and oil cooler, which by the way are installed in series.
It works- hundreds of these planes have been flying all over the place for years.
