Day 2
I was feeling the after effects of the food poisoning (dehydration & blood sugar out of balance) from yesterday and was barely functional until noon.
Despite the challenges, I was able to close the case, Install the 5th bearing, ring gear, gold hub, safety shaft, and castle nut.
One of the advantages of the supervised build is the specialized tooling William has made. For example on the right side, you can see a U shaped piece of HDPE which is used to secure the crank shaft. These tools and William's methods make the assembly much quicker.
