BRS wrote:Mike I believe we might not be reading the schematic the same way. The wire the 20A fuse is on seems to be the main wire that is carring all the load (current not voltage) to the main-"buss".
As stated by someone else, it is questionable if the 20 amp fuse is needed by argument can be made for it or it could be placed on the battery before the contactor. Much like a fusable link on a car. I do agree the obvous, that the solinoid wire from the contactor to ground (via master switch) is of low current and less often fused.
mike.smith wrote:I have an inline fuse between the positive battery terminal and the voltage regulator (to protect from over voltage),
gammaxy wrote:I'm not completely convinced the root cause has been identified.
I'm also not sure how the butt splices would have caused the fuse to melt. Unless I'm not interpreting the picture of the melted fuse correctly,
