I started off with a #2 needle. Got it dialed in and was really happy with it. Then I had to screw with things and I added fresh air induction. There is a whole thread about it, including my experiments:
viewtopic.php?f=7&t=4465After fresh air induction, and before I got the mixture balance between cylinders figured out, I tried a #2.5 needle. It was way too rich all the time, except for WOT. I went back to the #2 and was happier.
But then I messed around some more with induction/balance and really got it running great. Except now that it is cold, it's way too rich at idle and cruise and too lean at WOT.
So Brock made this awesome picture explaining the difference:
You can find that here and other places:
viewtopic.php?f=33&t=1791&p=52567I recently ordered a couple more #2 needles. I'm going to tweak mine leaner, mark the spot at WOT where the needle is just entering the fuel orifice, and then do some tapering from just below to just above that WOT spot. Somebody else did some custom needle tapering, but I can't find the thread. The two extra needles are in case I screw up.
I also run 100LL with decalin and I measure EGT at every cylinder. #1 is the hottest for me but after all the screwing around with my intake manifolds all the other ones are within 120F of #1. Not quite as good as the VeeCU but I'm pretty happy with that level of balance.
Also for reference my intake mods can be found here in this thread:
viewtopic.php?f=7&t=3232&start=130
