by fastj22 » Sun Mar 16, 2014 9:45 am
Wiring the MGL xtreme is easy. Ground, 12v power, external alarm switch wire, and a single signal wire to the RDAC. Another to the Ahrs and compass if you use them. All through a single db9 pre-wired connector. The RDAC is pretty simple too. Each sensor lead has a screw down socket.
I thought I would use the checklists too, but I like my old school flip chart checklist. Also, when using the checklist on the display, you can't see some of the stuff you are checking.
