Sonex-A purchase - What to look for
Re: Sonex-A purchase - What to look for
Postby Area 51% » Thu Oct 31, 2024 7:14 am
Hambone wrote:Also, one spring that connects the two sections of the exhaust on one side is stretched nice and tight, and the other one is much less tight. Is this an issue? Also, the previous owner ran safety wire down the middle of the exhaust pipe connector springs. Is this necessary?
I personally believe it a necessary add-on. Springs can lose their tension when they get hot allowing the pipes to separate and vent exhaust gases directly on the injector/carb. I experienced such a failure that caused total vaper-lock with a resulting uneventful emergency landing.
At the very least, if you wrap the pipes, keep the springs on the outside of the wrap.
Area 51%
Postby BRS » Thu Oct 31, 2024 8:17 pm
I used to fly a gyroplane, think pusher propeller. The exhaust had about six springs which did a real job when going through the propeller. Wire through the springs were a must. The other thing we did was to run a generous bead of high temp silicone across the stretched springs. Gotta do what you gotta do. In the Sonex I guess it's more about not torching things under the cowl as it's not so likely a runaway spring is going forward.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby Hambone » Fri Nov 01, 2024 3:16 pm
Thanks for the replies. I'll run safety wire in the middle of the springs. It can't hurt, and could possibly help.
Hambone
Postby bvolcko38 » Sun Nov 03, 2024 10:40 am
Add some red RTV to the springs...it keeps them from vibrating causing metal fatigue.
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Return to Safety and Training
