BRS wrote:DCASonex wrote:Using my Dyna-Vibe balancer with a wood Sensenich prop on my CAMit 3300, was able to bring it nicely in balance by just adding some large washers under the nuts of the prop bolts. That was about 3 or 4 years ago, time to do it again.
I've the same balancer. I should at least give it a try and see how far out of balance I am (the plane not me). Really though, in flight it feels smooth, it's just that if there is something to be tweaked (in a good way) why spend my time flying when I can find a reason to be wrenching. Ha.
Kai wrote:Brock,
...With a prop bolt DIAMETER of only 4-3/8 in, I´m surprised you managed to balance anything at all :-)
Hambone wrote:A few questions. The engine hasn't been run in almost 5 months, and only flew 7 hours after the previous oil change. It now has shiny new heads, which hopefully won't suffer the rear cylinder exhaust valve damage like the previous engine. Should I change the oil again? What about cleaning the oil screen? Also, the Penn oil is a lot more expensive than the Valvoline. Is there a problem swapping over from Penn to Valvoline?
