Flap position display
Panel designs, construction methods, and pictures
Postby dboeshaar » Fri Jun 07, 2024 2:20 pm
I'm building the Sonex Model B and the flap motor has the position sensor built in. BUT What display do I use on the panel?
advTHANKSance
Dkb
David Boeshaar
KWHP
TDAIRCRAFT.COM
My Greatest Fear: What if the Hokey Pokey really is what it's all about?
dboeshaar
Re: Flap position display
Postby XenosN42 » Fri Jun 07, 2024 5:23 pm
Most full featured EFIS will be able to display the flap setting. Refer to their manuals, most are available for free on the vendor’s websites.
-- Michael
OneX N169XE
XenosN42
Postby pfhoeycfi » Tue Oct 29, 2024 6:26 pm
dboeshaar wrote:I'm building the Sonex Model B and the flap motor has the position sensor built in. BUT What display do I use on the panel?
advTHANKSance
Dkb
Actuonix makes an indicator, works great. $24 on amazon.
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Postby WaiexB22 » Tue Oct 29, 2024 6:40 pm
You can feed it onto anything with a canbus. Mine is a little unique, but I fed it into the AEM display for my ECM which acts as my engine monitor. I also integrated trim position and fuel level there.
viewtopic.php?f=29&t=7748
Robert
Waiex-B 0022
Yamaha Apex
Building
WaiexB22
Postby Skippydiesel » Tue Oct 29, 2024 7:23 pm
Look out the window!
Skippydiesel
Postby BRS » Wed Oct 30, 2024 10:21 am
Skippydiesel wrote:Look out the window!
Yeah, what he said. ;-)
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby GordonTurner » Wed Oct 30, 2024 11:45 am
Actually, the potentiometer in the flap actuator has nothing to do with a can bus. Three wires are power ground and “brush” or the variable resistance wire. Wiring is simple, good explanation here, any Efis can accept this input and display position:
https://www.build-electronic-circuits.c ... ntiometer/
GordonTurner
Return to Panel
