Sonex tires?
Sonex tires?
Postby mike.smith » Thu Oct 10, 2024 6:50 pm
I've been using the Chan Shin 11 x 4.00 x 5 tires for the past 10 years. They don't seem to be available anymore. What are others using these days?
Re: Sonex tires?
Postby karmarepair » Thu Oct 10, 2024 7:48 pm
Check Azusa Karting tires, or Carlstar golf cart tires (Summit sells them)
karmarepair
Re: Sonex tires?
Postby daleandee » Thu Oct 10, 2024 8:14 pm
mike.smith wrote:I've been using the Chan Shin 11 x 4.00 x 5 tires for the past 10 years. They don't seem to be available anymore. What are others using these days?
These? https://www.aircraftspruce.com/catalog/ ... -02952.php
Re: Sonex tires?
Postby Skippydiesel » Fri Oct 11, 2024 12:55 am
How about this innovation ? ;
https://www.michelin.com.au/michelintweel/turf-care
Small ones are about $216 US each
Skippydiesel
Re: Sonex tires?
Postby markschaible » Fri Oct 11, 2024 9:21 am
These are available on the Sonex Web Store, as they have always been: https://www.sonexaircraft.com/eshop/car ... ring=azusa
markschaible
Re: Sonex tires?
Postby N111YX » Sat Oct 12, 2024 7:09 am
Make sure to confirm that the tubes that you find are compatible. I've ended up with tubes that have the stem offset from the centerline of the tube. These don't work with the Azusa wheels. I can't remember exactly where I got them as they have been around as backups but I'm thinking that buying Azusa branded tubes will solve this problem.
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
