Skippydiesel wrote:Just speculating Murray,
Bracket going to be interesting, as will have to accomodate Sonex very sloped firewall.
Strengthen firewall with either an aluminium plate (with lightening holes) OR a couple of aluminium angles, from aged memory, comes in 1.2- 3 mm gauge, equal or unequal sides, from about 10-50 mm. Can be had in short lengths from Bunnings Aerospace (depending on size you want, I might have a bit to spare)
Skippydiesel wrote:Be careful Murray - Rotax have specifications for the oil tank height, relative to the pump.
"I might copy this one from Skytek....."
Looks like you could get much of the aluminium extruded profile from Bunnings OR almost any specialised aluminium supplier (I used to use Ullrich - now closed)
"Interested to see how others have mounted theirs."
Mine is mounted on the starboard engine frame, fairly close to the firewall. Give me a date/time & I will fly in to Goulburn.
CaseyCooper wrote:Murray,
Yes. My tank is mounted on the firewall and all my kits come with the necessary bracketing to mount an oil tank to the firewall. I have a tapered bracket that I make out of 1 piece of 0.040” 6061 and 2 hose clamps, secured with rivets. Simple and effective. It keeps the tank vertical and the middle of the tank is as high as the middle of the engine (just above the gear leg truss). I mounted mine right behind the engine just left of the center seam in my Sonex. It’s been there for 400+hours. No complaints. I’ll see if I can get a picture of the brackets I make and post it tomorrow
