BRS wrote:[
Here is how I installed aileron (& elevator) electric trim.
viewtopic.php?f=3&t=6075&start=10#p45849
BRS wrote:The same rayallen servo I used on the wing could be used under the seat to pull the bungee. There is probably a simpler way but what come to mind is...
one bungee pulling left (balancing bungee) and another pulling right but connected to the servo.
I just went with the aileron trim tab (before ever flying the plane or any sonex) during the rebuild because that is what I have in the Sportsman and am used to it.
Herraripower wrote:Murray,
I have thought about it, and I have shimmed for it and it makes a bit of a difference! Your plane looks wonderful. I hope you’re having great success building time in it. I had made considerations for that when designing my cowl. The engine had a tendency to pull down and left under load. If using a ring mount it would be less pronounced but I’m using the bed mount.
Did you use the Sonex mount or make your own?
Users browsing this forum: Google Adsense [Bot] and 20 guests
