ECU mounting location
Discussions for ULPower engines.
Postby jmtraylor » Mon Jan 08, 2024 5:51 pm
Looking for lessons learned on mounting location of the ECU for UL 350 on the Sonex B.
Trying to determine best location. Pictures would be great as well.
Mark
Sonex 1222-B
Mark Traylor
Sonex #1222B
Helena, AL
jmtraylor
Re: ECU mounting location
Postby tmritter44 » Sun Jul 21, 2024 4:15 pm
I put ECU and the capacitor on aft side of the firewall with passthrough for the wire harness.
Location worked well for wiring from engine and to the instrument panel.
Plan to add insulation under the ECU.
See pictures on my EAA builders log at: https://eaabuilderslog.org/?s=Sonex0035
tmritter44
Postby Kai » Mon Jul 22, 2024 12:59 am
ECU goes on the cold side of the firewall. I put mine on amounting plate on the fuselage side plate, passenger side. That way I have a chance to get at it once the instrument panel is riveted in place- under the tank and obstructed by the pedals is hopeless. Get the fuel pumps and the fine filter as low down on the firewall as possible- there is a slightly reduce chance of heat radiation down low. I have seen many fuel pump installations with an additional heat shield for protection.
Sonex A #0525- SG, DS.
Kai
Postby Skippydiesel » Mon Jul 22, 2024 2:18 am
Put my delicate electronics on the aft /cool side of the firewall, with their own cool air supply taken/T off one of the cabin vents. So far so good.
Skippydiesel
Return to ULPower
