by SonexN76ET » Wed Jul 24, 2024 4:57 pm
Please be careful removing and reinstalling the intake elbows. I don’t recommend you remove them while removing the top spark plugs. Each time you remove and reinstall the intake elbows you create the risk of an induction air leak that will lead to a cylinder running lean and therefore hotter than it should. Just be careful with the spark plug installation. Make sure you properly seat them, screw them in initially with your fingers, make sure they are not cross threaded before you apply torque with a socket. If you have to put a time sert in later it is easy to do. I would not do all of the spark plug holes as time serts because there is not much distance from the bottom and top plugs to the valve ports. If you end up taking too much material out when prepping the time sert hole, you may end up too close to the valve ports and then you will likely get a crack.
Jake
Sarasota, Florida
