by sonex892. » Sat Jun 08, 2024 9:36 pm
Hi The Rdac XF has 3 Dip switches to select FIlter, Ballast and high gain plus a sensitivity potentiometer. If you are connected to the P lead for the tacho you pressumably have a 10k resistor.
First make note of all the current switch positions on the RDAC
Try adjusting the sensitivity gain adjust to see if that helps
These are the dip switch positions I think you should have selected when using the P lead
Noise filter ON
Ballast resistor OFF
High gain OFF
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
