by n502pd » Sat Mar 29, 2014 12:43 am
To get the solder to stick easier, and be 'sucked' into the inner strands, use a liberal ammount of plumbers flux. should be able to find it at a good hardware store. Also use a small propane torch, or at least a 200 watt solldering gun.. I have been doing this very thing for many years and if you cut the cable with sharp cutters about 1/2 in into the length of soldered cable, it will stay together.. Practice does help!!
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
